Tänkte kolla hur det står till med detta eftersom jag ser att hävarmen är olika justerade på de två. Hittade lite info på utrikiska, skulle vilja ha ett par förtydliganden på svenska Se nedan:
Hur justerar jag dem sinsemellan de tre när det bara är en stång att skruva på?- Accelerator Pump Volume
Measure the accelerator pump volume at each of the 6 nozzles. Before starting the car, turn the key "on" and energize the fuel pump. Let the pump run a minute or so to fill up the float bowls. The air cleaners are off. Now, lower the vial down the throat of barrel No. 1 and park it directly under the nozzle. Have the assistant in the car depress the gas pedal all the way, nice and easy. Withdraw the vial, record the results on a piece of paper, and dump the contents of the vial. Repeat at each nozzle. (You may have to remove the velocity stacks for cylinders 2, 3 and 6 to gain proper access to the nozzles for those barrels.) Adjust the nut on the accelerator pump rod as necessary. Turning the adjuster nut out will increase the amount injected, and vica versa. You want .6 to .8cc (ml) (.75cc works great). Get them all even.
Jag tänkte göra det på bänken, hur fyller man på bensin lämpligast då? Kan jag ta bort nålventilen och hälla på där eller, men hur får jag då bara i den kammare som har "avloppet" Måste man helt enkelt ta av ovandelen och blotta flotörena?This procedure can also be done on the bench. Just fill the float bowl that has the brass valve in the bottom that feeds fuel to the accelerator pump. Then activate the pump and measure. The advantage of measuring at this stage, as opposed to when the carburetors are attached to the intake manifolds, is that if there is a blockage, it is easy to get at the check valves, nozzles, pumps, and float bowl valves and clean them out.
God Jul
