The type numbers were the same for the 1968 engines with both the sand cast aluminum crankcase and the die cast magnesium crankcase. For the US cars the Type numbers were 901/14 for the manual transmission at 901/17 for the Sportomatic transmissions. These would be last numbers of the sand cast series: 901/14 3280631, 901/17 3380148
Beside the serial number the best way to tell is by looking at the crankcases. The sand cast aluminum crankcase has a rough sand cast finish and has sort of a bright silver look. The sand cast aluminum crankcases also had fins on the bottom of the crankcase, which the magnesium crankcase did not have. The die cast magnesium crankcase has a very smooth finish and a modeled gray color. The gray is the Dow Corning finish that Porsche used to slow down the corrosion process.
