Olja i växellådan ?
petter
Olja i växellådan ?
Post by petter » Sun Mar 15, 2020 9:57 pm
Re: Olja i växellådan ?
Post by henca » Mon Mar 16, 2020 7:58 am
Swepco 201
Christoffer E
Post by Christoffer E » Mon Mar 16, 2020 10:46 am
Porsche 912 Coupé 1969 Silver
Post by felix83 » Mon Mar 16, 2020 5:48 pm
Samma här!
924 Targa -77
PP930
Post by PP930 » Tue Mar 17, 2020 6:56 pm
Swepco 201
Kör oxå med den här.
Mvh/Pär
johan_a
Post by johan_a » Tue Mar 17, 2020 10:20 pm
Kört Swepco 201 i några år.
Länkar till produktdatablad:
911 Targa 2.7 -77
Post by MagnusW » Wed Mar 18, 2020 11:53 am
Swede356
Post by Swede356 » Fri Mar 20, 2020 10:11 am
Trevlig helg önskar,
Mikael
anka
Post by anka » Fri Mar 20, 2020 12:46 pm
Hej Mikael,
Ska jag PM dig uppgifter?
Mvh, Andreas
911 Carrera 3.0 Coupé -77
Swede356
Post by Swede356 » Fri Mar 20, 2020 2:38 pm
Hej Andreas,
En dunk räcker och blir över.
PM:a dina uppgifter tack.
Hälsar,
Mikael
Christoffer E
Post by Christoffer E » Sat Mar 21, 2020 8:28 am
