Hittade en kommentar på Pelican angående sådana här som ni kan tänka på :
Weber has always had the "name", but I think Zenith's are way under rated. The float design was far superior to the Weber...in fact PMO copied the pivot design of the float to eliminate hard turn starvation! The parts availability is not an issue anymore. The Zeniths can be modified & jetted to give you similar performance to the Weber, with some advantages that maybe superior to the Weber!
