http://www.hot-spark.eu/distributorlistbosch.html
Porsche 4-Cylinder
For 12-volt, negative ground electrical systems only
Bosch Distributor VE 4 BRS 383 (VE4BRS383) - 3BOS4C2
Bosch Distributor VJ 4 BR 9 (VJ4BR9)- 3BOS4C2
Bosch Distributor VJR 4 BR 18 (VJR4BR18) - 3BOS4C2
Bosch Distributor 0 231 129 022 - 3BOS4C2
Bosch Distributor 0 231 129 031 - 3BOS4C2
1948-1955 Porsche 356 - Bosch VE4BRS383 - 3BOS4C2
1955-66 Porsche 356 - Bosch 0 231 129 022 (with right-hand, 2-piece points) - 3BOS4C2
1956-1957 Porsche 356 - Bosch VJ4 BR9 (VJ4BR9) - 3BOS4C2
1958-1963 Porsche 356 - Bosch VJR4 BR18 (VJR4BR18) - 3BOS4C2
1964-1967 Porsche 356/912 - Bosch 0 231 129 022 - 3BOS4C2
1966-67 Porsche 912 - Bosch 0 231 129 022 (with right-hand, 2-piece points) - 3BOS4C2
1968-69 4-cyl 912 (with 1-piece, left-hand points) - 3BOS4U2L
1968-69 Porsche 912 - Bosch 0 231 129 031 - 3BOS4U1
1969-79 Porsche 912, 914, 924 - Bosch 0 231 170 xxx - 3BOS4U1
1970-76 Porsche 914 - 3BOS4U1
1976 Porsche 912E - 3BOS4U1
1976-77 Porsche 924 - Bosch 0 231 170 202, 0 231 176 064 - 3BOS4U1
1969-72 Porsche 914, 914/4 - Bosch 0 231 172 007, 0 231 174 001, 0 231 175 001 - 3BOS4U1
1972-73 Porsche 914 (1.7 Liter) - Bosch 0 231 175 005 - 3BOS4U1
1973-74 Porsche 914 (1.8 Liter) - Bosch 0 231 168 009 - 3BOS4U1
1972-75 Porsche 914 (2.0 Liter) - Bosch 0 231 174 009, 0 231 174 011 - 3BOS4U1
1976-81 Porsche 924 - Bosch 0 231 170 202 - 3BOS4U1
All air-cooled Porsche retrofitted with these Bosch 4-cyl distributors
(12 volt, negative ground only):
Bosch VE 4 BRS 383 (VE4BRS383) (with 2-piece, right-hand points) - 3BOS4C2
Bosch VJ 4 BR 8 (VJ4BR8) (with 2-piece, right-hand points) - 3BOS4C2
Bosch VJ 4 BR 9 (VJ4BR9) (with 2-piece, right-hand points) - 3BOS4C2
Bosch VJR4BR18 (with 2-piece, right-hand points) - 3BOS4C2
Bosch VJ 4 BR 24 (VJ4BR24) (with 2-piece, right-hand points) - 3BOS4C2
Bosch VJ 4 BR 25 (VJ4BR25) (with 2-piece, right-hand points) - 3BOS4C2
Bosch 0 231 129 010 - 3BOS4C2
Bosch 0 231 129 019 (JFR4) (with 2-piece, right-hand points) - 3BOS4C2
Bosch 0 231 170 034 - 3BOS4U1
Bosch 0 231 178 009 - 3BOS4U1
Bosch 9 230 081 050 - 3BOS4U1
Bosch 9 230 081 094 - 3BOS4U1
Porsche 6-Cylinder
(12-volt, negative ground electrical systems only)
1965-67 6-cyl 911, 911S, 911T, non-vacuum-advance (with 2-piece, right-hand points) - 3BOS6C2
1968 Porsche 911L, 911T (with 1-piece, left-hand points) - 3BOS6U2L
1968-1969 Porsche 912 (with 1-piece, left-hand points, vacuum-advance) - 3BOS6U2L
1969-71 6-cyl 911, 911E, 911S, 911T (with 1-piece, right-hand points) - 3BOS6U1
All '72 911 models, and some early '73 models used:
1972-73 Porsche 911T 2.4L Bosch 0 231 169 003 - 3BOS6U1
1972-73 Porsche 911E 2.4L Bosch 0 231 169 004 - 3BOS6U1
1972-73 Porsche 911S 2.4L Bosch 0 231 169 005 - 3BOS6U1
Later '73 911 models used:
1973 Porsche 911T 2.4L Bosch 0 231 169 008 - 3BOS6U2L
1973 Porsche 911E 2.4L Bosch 0 231 169 009 - 3BOS6U2L
1973 Porsche 911S 2.4L Bosch 0 231 169 010 - 3BOS6U2L
1972-73 Porsche 911, 911E, 911S, 911T - to May, 1973 (with 1-piece, left-hand points) - 3BOS6U2L
1972-73 Porsche 911, 911E, 911S, 911T models, to May, 1973 (with 1-piece, left-hand points) - 3BOS6U2L
1973 911, 911E, 911S, 911T models to May, 1973 (with 1-piece, right-hand points) - 3BOS6U1
1973-1974 Porsche 911E (with 1-piece, right-hand points) - 3BOS6U1
1973-1977 Porsche 911S (with 1-piece, right-hand points) - 3BOS6U1
1974-1975 Porsche 911 Carrera (with 1-piece, right-hand points) - 3BOS6U1
1974-77 911, 911S, Carrera (with 1-piece, right-hand points) - 3BOS6U1
1974-77 Porsche 911, 911S - Bosch 0 231 184 001 (with 1-piece, right-hand points) - 3BOS6U1
1973 6-cyl 911, 911E, 911S, 911T models to May, 1973 (with 1-piece, right-hand points) - 3BOS6U1
1974-77 6-cyl 911, 911S, Carrera (with 1-piece, right-hand points) - 3BOS6U1
Porsche 6-cylinder with Bosch Distributor Numbers:
0 231 121 006 - 1965-67 911 - 3BOS6C2
0 231 142 003 - 3BOS6U1
0 231 159 001 - 1966-67 911T 2.0 L, 1967 911L 2.0 L - 3BOS6C2
0 231 159 002 - 1967 911S 2.0 L - 3BOS6C2
0 231 159 006 - 1969-71 911E 2.0/2.2L - 3BOS6U1
0 231 159 007 - 1969-71 911S 2.0/2.2 L - 3BOS6U1
0 231 159 008 - 1970-72 914/6 2.0L - 1970-71 911T 2.2L - 3BOS6U1
0 231 162 001 - 3BOS6U1
0 231 162 002 - 3BOS6U1
0 231 169 001 - 1968 2.0 – 3BOS6U1
0 231 169 003 - 1972-73 911T 2.4L - 3BOS6U1
0 231 169 004 - 1972 911E 2.4L - 3BOS6U1
0 231 169 005 - 1972 911S 2.4L - 3BOS6U1
0 231 184 001 - 1974-77 Porsche 911, 911S - 3BOS6U1
0 231 184 002 - 3BOS6U1
0 231 184 003 - 3BOS6U1
0 231 184 004 - 3BOS6U1
0 231 184 007 - 3BOS6U1
0 231 184 008 - 3BOS6U1
0 231 185 009 - 3BOS6U1
0 231 185 010 - 3BOS6U1
0 231 185 011 - 3BOS6U1
0 231 187 001 - 3BOS6U1
0 231 187 002 - 3BOS6U1
VJR6BR62 - 3BOS6C2
Lista Bosch tändningsfördelare, brytarspetsar
