Just det, av nâgon outgrundlig anledning har jag lyckats komma över frâgorna(pâ den här sidan:http://www.nordstern.org/Tech/techQuiz93/93_TecQ.txt) till det refuserade spelet "trival early911", det var tänkt att tillverkas i oljebeständig papp till en mycket smal grupp människor!
Har ni en timme eller 2 över?
EARLY 911 SPECIFIC QUESTIONS
61) The clutch pedal freeplay adjustment for the 1972 911 should be 13/16" to 1".
a) True
b) False
62) According to the Porsche "Technical Specification" booklets, the maximum
oil temperature for all 911's through 1973 was:
a) 130deg. C
b) 212deg. F
c) 260deg. F
d) I don't know; my 911 always overheats!
63) All early 911's and 912's use head gaskets or seals
a) True
b) False
64) The 1976 Turbo used the oil tank from a Sportomatic equipped 911.
a) True
b) False
65) An approved spark plug, as of March 1967, for the Type 2000 engine was the
Champion N6Y.
a) True
b) False
66) According to the "Emission Equipment and Tune Up Specifications" booklet
from Porsche, the correct engine idle rpm for the 1968 through 1976 911 (all
models) is:
a) 850 ± 100
b) 900 ± 50
c) 950 ± 100
d) 1000± 50
e) none of the above
67) All 911's and 912's have overhead valves.
a) True
b) False
68) The early 911/912 suspension consists of independent suspension struts and transverse control arms in front, with independent, semitrailing arms in back, with torsion bar springs at all four corners.
a) True
b) False
69) The number one cylinder is at the _______ for the '66-69 912 and at the
_______ for all 911's, respectively, relative to the direction of travel.
a) right rear, left rear
b) left rear, left rear
c) right front, left rear
d) right rear, right rear
70) In January of 1970, Porsche won the Monte Carlo Rally. One thing that made
this event unique was that:
a) Porsche took 1st, 2nd, & 3rd
b) It was the first time in the history of the rally that one manufacturer
had won three times in a row
c) They used 911T's in the rally
71) The proper firing order of 911's is:
a) 1-6-4-2-3-5
b) 1-5-4-2-6-3
c) 1-6-2-4-3-5
d) Any of the above depending on how you cross wire the distributor cap
72) All 912's had their camshafts driven by:
a) Chains
b) Gears
c) Belts
d) a & b
73) Porsche introduced the 912E in Model year:
a) 1974
b) 1975
c) 1976
d) 1977
74) Ignition timing for the 1968 911L, the 1969 911E & S and the 1970-71 911E
& S was:
a) 30deg. BTDC @ 6000 rpm
b) 35deg. BTDC @ 6000 rpm
c) 30deg. BTDC @ 6500 rpm
d) 5deg. ATDC @ idle
75) The Targa model of the 911 series became an option in what model year:
a) 1969
b) 1968
c) 1966
d) 1965
76) The 1969 model year was the last for the 911L to be offered in the U.S.
a) True
b) False
77) All 911S's had fuel injected engines.
a) True
b) False
78) 911's have had normal production bodies manufactured by:
a) Porsche
b) Karmann
c) Reutter
d) a & c
e) a & b
79) 1969 marked the first year of what major ventilation improvement:
a) Air conditioning was made standard
b) The heating vents were removed from the sills and now controlled from
the dash
c) The front quarter windows were made movable
d) b & c
80) The 911R prototypes, bodies built by Baur, were manufactured in what year:
a) 1966
b) 1967
c) 1968
d) 1969
81) Two special 911's that Porsche offered in 1975 and 1976 respectively,were:
a) Signature and Silver Anniversary
b) Weissach and Signature
c) Silver Anniversary and Weissach
d) Silver Anniversary and Signature
82) 911's have how many lug bolts:
a) 16
b) 20
c) none of the above
83) 911 belt tensioning instructions state that shims not used between the
pulley halves should be discarded.
a) True
b) False
84) A special Rally Kit for the 911 was offered in 1968, was homologated with
the F.I.A., and was based on what model:
a) 911R
b) 911T
c) 911E
d) 911S
85) The first Porsche production car use of internally vented disc brakes on
all four wheels was on the model year:
a) 1967 911S
b) 1966 911
c) 1968 911L
d) 1965 911
86) One of the primary body changes to the 1972 model year 911 from the 1971
model year 911 was:
a) new design, crash resistant front and rear bumpers
b) "blackout trim" on the window frames
c) a front spoiler bumper
d) outside oil filler cap
e) c & d
87) According to both "Car and Driver" and "Road & Track," the top speed of the
1976 model year 930 Turbo was:
a) 180 mph
b) 167 mph
c) 156 mph
d) 143 mph
e) 191 mph
88) The approximate crankshaft to blower ratio for the 1976 and 1977 model
911's was:
a) 1:2.0
b) 1:1.8
c) 1:1.5
d) 1:1.2
e) 1:3.0
89) The compression ratio of the 1976-1977 model Turbo was:
a) 6.0:1
b) 10.1:1
c) 7.0:1
d) 6.75:1
90) According to "Excellence Was Expected", the Turbo model, first offered
in Europe in 1975, introduced the aluminum alloy front crossmember which carrys
the front suspension mounts. The aluminum crossmember was introduced on all
911's in the 1976 model year.
a) True
b) False
91) The standard forged alloy wheel size on the 1967 model 911S was 15 x 5.5
inches:
a) True
b) False
92) U.S. model interior lights for the 1969, 1970, and 1971 model 911's were
of the following wattage:
a) 10 w
b) 60/50 w
c) 100 w
d) 15 w
93) Bilstein shock absorbers were standard equipment on the '73 911 Carrera RS
in 1973.
a) True
b) False
94) In 1974, an electric blower was added in the engine compartment of all
911's, except European Carreras, supplying air for the heating system.
a) True
b) False
95) The 21.13 gallon fuel tank of the U.S. model 1975 911S and Carrera had a
reserve of what capacity:
a) 1.9 U.S. gallons
b) 7 liters
c) 1.7 Imperial gallons
d) 2.1 U.S. gallons
96) The late Mark Donohue beat the late Peter Gregg in the first appearance of
the Carrera RSR's at Daytona in February, 1973.
a) True
b) False
97) Porsche won the Tour de France outright with a 911R in what year:
a) 1966
b) 1967
c) 1968
d) 1969
98) A 911 has taken Fastest Time of Day at the last three Porsche Parades (not
including this year).
a) True
b) False
99) What International Race of Champions driver in 1974 likened the 911 to a
"$12,000 imported Corvair":
a) Richard Petty
b) Peter Gregg
c) David Pearson
d) Bobby Allison
100) The type 916 engine was used in what Porsche model prior to being
installed in the 911R:
a) 904
b) 906
c) 907
d) 910
Sedan fyller ni i ert resultat i pollen och vi kan pâ sâ vis sedan läsa ut vilken typ av early 911 ägare ni är (om ni nâgonsin undrat) samt pà vilken nivâ vi mâste förbättra forumets snitt kunskaper!
Sâ här tolkas de rätta svaren:
0-5 Det gör inget, du vet säkert vad det kostar att byta olja i en nissan micra
6-10 Tur att du kör Porsche, annars skulle tjejerna aldrig snacka med dig.
11-20 Kör du folkvagn eller?
21-30 Börjar bli seriöst,du har läst pâ, men spara lite till innan du byter in 944án
31-35 Bra gjort, men det är inte sâ mycket att skryta med det fick ungefär alla andra som varit med pà forumet ocksâ
36-39 Du, man hade faktiskt bara 3 livlinor och det är fult att fuska
Nedan följer SVAREN:
61) Answer: a)- "1972 911E Owner's Manual, USA," page 71
62) Answer: a)- "Porsche Technical Specifications" booklets; through Dec 1967, page 15; 69, 70, 71 Models, page 15; 72 & 73 Models, pages 14 & 15
63) Answer: b)- "Porsche 912 1965-69 Autobook," page 15 (and other references)
64) Answer: a)- "Turbo Carrera Self Study Program, Model 1976," 4545.21, page 10
65) Answer: a)- "911 Workshop Manual," page L41
66) Answer: b)- "Emission Equipment and Tune Up Specifications," Part No. PNA 000023, pages 1-6
67) Answer: a)- "1975 911S/Carrera Owner's Manual," page 9 "912 Driver's Manual, Edition VII/67," page 95; and others
(Note: I did NOT say overhead cams!)
68) Answer: a) "1975 911S/Carrera Owner's Manual," pages17 & 18: "912 Driver's Manual, Edition VII/67," pages 88 & 89, and others
69) Answer: c)- "912, 911, 911T, 911L, 911S Technical Specifications" booklet, pages 54 & 108
70) Answer: b)- "Excellence Was Expected," page 626 & 627
71) Answer: c)- "912, 911, 911T, 911L, 911S Technical Specifications" booklet, page 54
72) Answer: b)- "912 Driver's Manual, Edition VII/67," page 84; "Excellence Was Expected," pages 764 & 560
73) Answer: c)- "Excellence Was Expected," page 764
74) Answer: a)- "Emission Equipment and Tune Up Specifications, 1968-1986, All Models," Part No. PNA 000023, pages 1-3
75) Answer: e)- "Excellence Was Expected," page 415
76) Answer: b)- "Excellence Was Expected," pages 450 & 519
77) Answer: b) "Excellence Was Expected," page 445
78) Answer: e)- "Excellence Was Expected," pages 407 & 413
79) Answer: b)- "Excellence Was Expected," page 613
80) Answer: b)- "Excellence Was Expected," pages 455 & 456
81) Answer: d)- "Excellence Was Expected," pages 758 & 766
82) Answer: c)- "911E Owners Manual, Edition 71," page 75 (911's have lug NUTS!)
83) Answer: b)- "911E Owners Manual, Edition 71," page 63, and others
84) Answer: b)- "Excellence Was Expected," page 455
85) Answer: a)- "Excellence Was Expected," page 444-445
86) Answer: d)- "Excellence Was Expected," page 626
87) Answer: c)- "Excellence Was Expected," page 795
88) Answer: b)- "911, Carrera 3.0, Turbo Technical Specifications, 76/77
Models," page12-13
89) Answer: e)- "911, Carrera 3.0, Turbo Technical Specifications, 76/77
Models," page12
90) Answer: a)- "Excellence Was Expected," page 789
91) Answer: b)- "Excellence Was Expected," page 445
92) Answer: a)- "911T, 911E, 911S Technical Specifications, 69, 70, 71 Models,"
page 95
93) Answers: a)- "Excellence Was Expected," page 728
94) Answer: b)- "Excellence Was Expected," page 758 (this happened in 1975)
95) Answers: d)- "1975 911S/Carrera Owner's Manual," page 26
96) Answer: b)- "Excellence Was Expected," page 726 (Gregg beat Donohue)
97) Answer: d)- "Excellence Was Expected," page 458
98) Answer: b)- "Porsche Panorama," Sept. '92, page 26
99) Answer: d)- "Excellence Was Expected," page 755
100) Answer: d)- "Excellence Was Expected," page 460
Dags att kröna Mr. early911 Knowitall!
